Prompted to login to install EDS files
phuz
Jun 2008
Mohnton, PA
1,046
Not sure when this started or what triggered it, but I went to install RSLinx enterprise on a XP VM, which resides on my ESXi server.
If I type my username and password, or the admin username and password, it shows the error below. If I type it incorrectly, it says invalid username or password. What in the world is causing this?
The RA Tech Notes are no help because they don't apply to this.
Seeing as I thought this was a Windows issue, I opted to just format/re-install the VM (since it only contains FTView, Panelbuilder32, and PB1400e). On a brand new installation of XP SP3, I am installing FTView 8.2 again and it prompts for the same username and password. What is going on?
FWIW, I also tried logging into Windows using the Administrator account and performing the install. Same results.
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
90
I used vmware converter to clone and backup a physical pc FT View client and now after removing vcenter converter and rebooting I am getting a...
89
I'm attempting to get a very old system running again that uses allenbradley plc / realview32 i have full access to the windows 2000 installation...
149
  • Locked
  • Sticky
Hi folks, If you're having any login issues kindly send an email to [email protected] or use the 'contact us' link on the bottom of every page to get...
1,295
I am working at a remote site that has a FTView SE system that has been running for years...V9. About an hour ago the operators called me over...
712
