phuz
Haven't really ever had an issue writing/reading to tags. FTView SE 8.2.
I have a button that is using &Set Tag 0 and I get this error. It eventually writes the value to the tag after about 30 seconds. If I don't use the &Set, and just use the "Set tag to 0", it works fine. I swapped my EBNT thinking it was causing communication issues, but nope. Everything appears to be working as it should, with the exception of the &Set commands on buttons.
