Hi
I have Factorytalk view ME on a PC. There is two plcs which it communicated with
PLC1 (1769-L32E)- communicates with no issue (read and write)
PLC2 (1769-L32E)- can read values but not write values
- Values which are read from the plc are updated with no issue
- Values which are written to the PLC give an error "Problem writing value 'TRUE' to item '[plc2]Test'"
As a test i created a bool "Test" in plc2, a numeric display and a pushbutton. If i change the value manually in the plc the numeric display will update with no issue. When the pushbutton is pressed i recieve the above error.
Has anyone come across this issue before?
