RSLinx pro and RSLinx lite, what is the difference?
shaarawi1984
Aug 2006
Amman
38
Hello;
Anyone knows what is the difference between RSLinx lite, and RSLinx pro. I have RSLinx lite and during my reading for many threads I saw some things that is not in my menu bar like OPC (I think so).
I use RSView32, and RSLogix5000 software, will RSLinx lite work with these type of software or not?
thank you
thank you
for RS L5K RSlinx lite is ok but for RSView32 you should use atleast Rslinx OEM
Hello;
Do you know if we use RSLinx with RSView32 what is the symptoms that indicate that we should use RSLinx OEM (for example). i.e RSLinx is not the suitable software in our case? (Like the communication will not appear, or the communication appear but will not work,....)
If you want to save a small amount of money, you can go for RSLinx Single Node in stead of RSLinx OEM.
The difference is that RSLinx Single Node only allows to connect to one PLC in stead of many, and the connection type is OPC - the direct drivers are not available.
There are some bundles of RSview32 with RSlinx Single Node.
Thank you rParaveenkum, and JesperMP for your replies.
In the project I study it in oreder to excute it, there are more than one PLC.
Thank you
Running redundancy for OPC topics (RSLinx Pro is the data server)...switched from primary to secondary so that I could add topics to the primary...
1,483
OK, so the time came to get a new computer so I went from one with XP Pro, SP3 to one with Windows 7 Pro, 64 bit. So, now how to connect to...
4,634
It's been a while since I have had to interface Excel with a AB PLC. Typically what has been done in the past is to use RSLinx pro as OPC/DDE...
12,538
More a curiousity what is the differents in these different types of RSlinx. I currently use the lite version 2.50 and have never encountered a...
2,558
I am running Control Logix, RSLinx Pro (v: 2.40.01), with RSView32 (v: 6.30.17) and my display has no data. My driver (ETHERNET) is properly...
20
9,655
