DH485, Windows 7 Pro (64b), RSLinx
johnd_125
Apr 2012
Missouri
146
OK, so the time came to get a new computer so I went from one with XP Pro, SP3 to one with Windows 7 Pro, 64 bit.
So, now how to connect to PLC's with DH485?
The 1747-PIC was what I used the most but it was always hit or miss. The new computer doesn't have a serial port and USB to serial adapters don't work with this.
My 1784-PCMK/B card worked good but this new card has an Express Card slot, which is about half the size of the old PCMCIA slots. Of course the adapters they make for that, don't work according to the AB knowledgebase
That leads me to the 1747-UIC, which appears to be the future. AB compatibility charts don't show that it works with Win7,Pro,64b. Of course they don't say it won't work, either. šŸ™ƒ In digging around, I found a youtube video where it looked like this version of windows, RSLinx V2.57, and the 1747-UIC, WOULD work together. True, or not?
AB KB is pushing the XP Mode or an RSLinx V3.56 as solutions,neither of which is too attractive.
Thoughts, ideas????
Thanks, in advance.
Yes, I'd seen that thread but since it was 5 years old I was hoping there was a better solution by now or that the confidence level was higher.
Its hard to argue with something that works, though.
What particular brand of express card adapter did you get? Was it the Duel systems?
Thanks.
The UIC works in Windows 7 64 bit. You have to use the DF1 driver though. When you configure it you have to select the COM port and 1770-KF3/1747-KE for the device. And maybe CRC for error checking.
If you need to get a UIC, I'd get the after market one here. It's almost half the price and has the RJ-45 looking end built into it.
Thanks.
The one I used was purchased here. http://www.shopdigi.com/product.aspx?pf_id=PC-EXP
The only reason to go this way is if you have invested in the PCMK card and cable(s) and prefer not to spend the bucks to get the 1747-UIC, and even more so the 1784-U2DHP USB to DH+ cable, which is very pricey. If you don't have that, or just want to go with the latest stuff, go ahead and get the new.
I have changed companies since I went that route, and now have a newer laptop and the UIC and DH+ USB cables. Both are working fine with my Win 7 64-bit laptop. Hope this helps. Let me know if you have any other questions.
USB to DH485 interface converter 1747-UIC works perfectly with windows 7 pro or home 64bit. See below what you need to do.
Plug in converter to USB port of Windows 64 bit computer and let windows install driver from Windows update, once Windows install drivers it will display as a usb serial with com port number in device manager under ports
That's it you can load any driver from rslinks, df1 or dh485 both will work
Hello all, i have seen a few things here and there about connecting to a panelview 550, however i still would like to ask a few things, I have...
135
Hi all, I had a setup with 2 Micrologix 1100 connected to a Panelview C300 over DH-485. I was mandated to upgrade the HMI, and proposed to...
893
Hello, We have an older machine that has a standard PanelView (2711-T10C3) connected over DH485 to a SLC 5/04 PLC via a 1761-NET-AIC module in...
674
Hi, I have a SLC5/03 connected to a working HMI via RE232 port, and connected to a broken HMI via DH485 (RJ45), I want to use the cable that used...
3,317
Hey all, long time reader but first time poster here. I've been tasked with an odd one and was wondering if anyone else had experience in this...
17
5,354
