SLC5/03 DH485 via Ethernet, possible?
marv_tech
Apr 2022
East Coast
25
Hey all, long time reader but first time poster here. I've been tasked with an odd one and was wondering if anyone else had experience in this.
I've got a SLC5/03 with a Panelview on the DB9 port with no option to remove. I can connect to it via the RJ45 DH485 port with a PIC or AIC+ adapter and go online with RSLogix without a problem.
I have been tasked with making this PLC monitorable via the network. I've tried a NET-ENI (which does DF1 to Ethernet/IP) with both the PIC and AIC+ adapter and no dice, I see the NET-ENI in linx but it doesn't see the SLC.
The UIC/AIC+ driver I use in Linx doesn't work when I try to set it up with a virtual COM port so ethernet to RS232 serial hosts haven't worked for me so far.
Anyone ever made this work? At some point it makes more sense to upgrade to a SLC5/05, but I'm hoping to find a cheaper option. Much thanks for taking the time to read my post.
Welcome to the PLCTalk forum community !
I am surprised that you can !
What OS are you running ? To my knowledge, the 1747-PIC/AIC+ driver stopped working after XP SP2 (SP3 if you applied a specific patch, hat tip to our forum member @dmroeder)), and simply doesn't work at all with Windows 7 or Windows 10.
Your experience with the Net-ENI is expected: the Net-ENI supports only DF1 Full Duplex point-to-point, and the 1747-PIC/AIC+ is true native DH485.
A virtual COM port (or a USB COM port) won't work with the 1747-PIC/AIC+ for similar reasons that a modern PC's native COM port won't: they can't access the handshaking features on the port fast enough.
There was a thread a while ago in which someone challenged the forum to set up a USB-over-TCP with a modern 1747-UIC USB to DH485 interface. I got it to work, but unreliably, and abandoned the effort.
I've got a few old laptops running windows NT/XP specifically for SLC5/03s as I have quite a few SLC5/PV combos in this configuration, running on borrowed time but still ticking for now! Running into these the first time after a few years of Micrologix experience was not a grand time. I misread the AIC+ documentation and thought it might do DF1/DH485 conversion internally, but my understanding now is that actually happens in the driver.
I hadn't thought of USB over TCP, that is a novel concept. Was it reliable enough for monitoring? Intended application is for one of our engineers to be able to view a few alarm and analog values via rslogix500, would never allow programming over such a link.
Thanks for the reply!
Would something like this work?
I suspect it would, the product description says "In Transparent PCCC mode, the user will be able to program and connect to SLC5/03 PLCs."
Only problem is the cost thru Rexel is similar to a SLC5/05 CPU replacement (used stock). Sure is tempting though, it specifically calls out my usecase. Much appreciate you digging.
I've connected 5/03's to an XP VM on a plant wifi network running RSLINX to accomplish something similar. The VM was network-bridged to the host that had all necessary firewalls and anti-malware software monitoring the connection. I wouldn't recommend this unless your network security is top-notch, but it does work, even if it is a PITA.
Thanks for the link Ken, I'm going to give that route a try as I've got some ras-pi's in house and might be able to get my hands on a USB<->Ethernet print server without too much grief.
JTCat, that sounds very interesting - I am having a little trouble picturing your setup. What was the physical connection to the 5/03? I'm lucky enough to have a mostly isolated production network with a robust firewall for our dual-homed server, so as long as I stay in LAN I am pretty safe.
Marv,
I have done this with a virtual serial port server. Ethernet to the PC, serial to the SLC. I believe I've used MOXA Nport that's compatible with DF1, there are several on the market.
Profisoft makes a DH485 -> E/IP gateway.
Either way you do this, expect to spend some money. I don't know how to see non-ethernet devices across a VM.
Some may question the need for a VM if using Ethernet, as I do sometimes. But some customers are adamant that they want to view processes without them being 'physically' linked to their plant network. So a bridged-to-wifi NAT adaptor accomplishes more or less the same thing. Like I said, it's a PITA, and to me it's not worth the effort if I wasn't getting paid to do it.
Marv,
I appreciate the insight, I've had success with DF1 via network serial port (both through an HMI passthru and a dedicated serial port server) but no luck when trying with DH485 (thru a 1761-NET-AIC+ and a 1747-PIC).
Was your setup a SLC5/03 485 -> Moxa NPORT -> Virtual Com Port? Or SLC 5/03 485 -> Physical Win XP PC with Serial Server -> Virtual Com Port on VM?
Since the adapters being suggested cost money, why not look for a used SLC5/05 on eBay. Depending on the memory words needed they start at $600 or $1000.
Changing the processor type from a 5/03 to 5/05 is simple in RSLogix, a quick verify and download. Anything a 5/03 can do the 5/05 will, just with an Ethernet port not DH485. That would also be less effort than setting up new unknown adapters.
On the side, I found it beneficial to tell the boss that his new idea is going to need something upgraded to get him more open to upgrades. Just say the 5/03 won't but a 5/05 will.
Yeah SLC5/05 is the plan if I can't find a cheaper way, they're just pricey. That said, they are about the same price as the dedicated solutions for Network RSLogix Monitoring to a SLC5/03 via DH485 and a SLC5/05 wins every time in that matchup.
I'm going to try USB redirection + UIC setup Ken linked to, seems promising and I've got a decent testbed environment to make sure it won't somehow interrupt a run-mode SLC. I need to buy a UIC anyway and the USB network devices are cheap. I'll post results!
I replaced a 5/02 a few weeks ago specifically because of the issues with the RH485 port.
Cost around £1500 for an ET200SP mounted S7-1500. Nearly half of that cost was relays due to the 110v controls and the only ET200 modules that could do it were on a 38 week lead time.
Not sure how this translates to US prices though and obviously it's only a cheap option if you already have the software licences to do it.
Hi, I have a SLC5/03 connected to a working HMI via RE232 port, and connected to a broken HMI via DH485 (RJ45), I want to use the cable that used...
3,297
Hi all I am experiencing a nuisance problem with a slc5/01. When going online to the plc, the comms appear to be very slow (ie the online icon...
4,667
Hi all, I'm working on a project replacing a failed SLC5/03 with a new ML1400. I've gotten the program updated and working, all the IO changed...
1,525
Hi everyone, I am new to this PLC forum and I have a question about this new project I am working on. I have a testing machine running on an old...
1,887
Dear, I have to communicate my SLC 5/04 CPU channel0 ,configured as DH485, i have an ethernet interface 1761 NET ENIW. I have read how to...
3,920
