AB SLC5/01 DH485 to DF1 OPC Server with Labview
yf12chen
Oct 2017
Toronto
Hi everyone,
I am new to this PLC forum and I have a question about this new project I am working on.
I have a testing machine running on an old 1746 SLC5/01 CPU and I am trying to create a Labview application to provide user interface and data acquisition/real time output waveform.
So I need to use National Instruments NIOPC server to interact with AB PLC. However NIOPC server only supports DF1/DH+ as the communication protocol with Allen Bradley.
So I am wondering if there is any solution to change DH485 to DH1/DH+ so my SLC501 can talk to Labview.
All answers would be appreciated.
If your LabView driver can handle Windows COM ports beyond 1-4 (or your Windows PC isn't using them), the best solution would be a USB-connected DF1 to DH485 protocol interface.
The Allen-Bradley part number is 1747-UIC.
On the USB side it emulates an ordinary Windows COM port, with the DF1 Full Duplex protocol.
Thanks Ken,
I just found some 1747-UIC in the lab. My RSLinx is able to find the plc through this converter and everything works fine. I am just waiting for the quote from National Instrument to try it on NI OPC server.
Again, thanks for the solution.
Hi there, I'm new to PLCS.net so I would like to send greetings from Darwin, Australia. I would like to connect either a K6C2 or B6C16 (I have...
3,058
Hi, I have a SLC5/03 connected to a working HMI via RE232 port, and connected to a broken HMI via DH485 (RJ45), I want to use the cable that used...
3,317
Hey all, long time reader but first time poster here. I've been tasked with an odd one and was wondering if anyone else had experience in this...
17
5,354
Hi all, I'm working on a project replacing a failed SLC5/03 with a new ML1400. I've gotten the program updated and working, all the IO changed...
1,525
Dear, I have to communicate my SLC 5/04 CPU channel0 ,configured as DH485, i have an ethernet interface 1761 NET ENIW. I have read how to...
3,923
