Help! Need wiring diagram of Serial Cable to connect Omron CPM2A to computer
CNCQuest
Feb 2007
Manila
Hi, all.
I just got an Omron CPM2A off eBay and I need to make my own serial cable to connect it to my computer for programming. I will be using the RS232C serial port of the PLC and not the peripheral port.
I had actually went thru this forum and read all the manuals but I can not seem to get a definitive answer to my problem.
Can someone please help? A wiring diagram or web resource will be a great help. TIA!
WT
Confused on the Signal Ground Pin #7 or #9
bluebyu said:
Tks for the above info. I made up a serial cable based on that and using Pin #7 in the Omron PLC side connecting to Pin #5 to the computer side. (Some other info seems to indicate it should be Pin #9 instead of Pin #7, any difference?)
However, I can not get my CX-programmer to auto detect the PLC. Am I doing something wrong here? Any help will be much appreciated.
Tks & best regards,
WT
Pin 9 on PLC should go to Pin 5 on computer.
Pin 7 was Signal Ground on the C--H product.
If pin 9 is not connected, that is probably your problem.
Also, which position is the switch in that is next to the 9 pin port?
Hope this will help.
Im a mechatronics instructor at a local community college. I have a couple of motor control questions and would definitely appreciate any help...
1,808
https://imgur.com/a/kKPtzyP We are making improvements to these motor controls by replacing these old resistor banks and DC generator with DC...
1,796
I intend to use a clickPLC to turn a motor on and off for predetermined times. I am still very new to this and not sure exactly how I wire...
1,541
A friend of mine and I are pulling out on old (failed) 484 system as a charity project for a propulsion system on a ship that is used for disaster...
1,237
Hi guys, I am confused about the way a power cord plug should be connected. We have a single phase, 200-240VAC, 50Hz machine. I have a plug...
4,227
