Need help understanding this old DC motor wiring diagram
741C
Oct 2019
CO
https://imgur.com/a/kKPtzyP
We are making improvements to these motor controls by replacing these old resistor banks and DC generator with DC drives. But, we have learned that evidently these motors are "series wound", meaning that the armature and fields are in series with eachother. But, the peckerhead has three leads into the motor. Two positives that are spliced together just before entering the motor. What are the two positives? What is the yellow lead? The third appears to be a negative. The motor says series wound which would suggest only two leads. Cant tell if there is a shunt coil inside or not – that would be a “compound wound” motor I think but could explain the third lead.
Thanks in advance.
The third lead will be the connection between the armature and the series field. To reverse a series motor, you must reverse the polarity of either the armature or the field without changing the polarity of the other. The third lead allows this to be done.
If you are going to convert this to a DC Drive, and need the motor to reverse, you must make provision to be able to change the polarity of just the armature or field. This is best left to a integrator who is experienced with DC Drives.
Be careful about getting the connections correct. If you put the series field in buck, it may eventually fry the motor. I used to use a 9V battery and an old anolog meter to test polarity (I found one that the leads were labeled wrong).
DSMR
You are confusing a compound wound motor, which has both a series and shunt field, with a series wound motor, which only has a series field. If the polarity of the field is reversed in a series wound motor, the motor will just run in reverse. No harm to the motor.
I get so confused by Rockwell's licensing structure. I have two PC's that will be running the same SE application. Can/should I run this as...
1,826
Good Afternoon , I'm sorry. But I'm struggling to understand this combination of integers in this MOV , and really anywhere else this scheme...
1,600
Hi folks, I am wondering if you guys can help me understand what the intended operation was for some logic that relates to the operation of the...
1,633
Good afternoon, I want to understand this old piece of logic I found in an old program (RS Logix 500 on SLC 5/03). I have two rungs here in a...
3,651
Hello guys, PLC 5 guy here who recently took a course through automationtraining.ca for some basic understanding on how to navigate through...
2,411
