need help understanding FTV SE network station
lftmx3
Feb 2014
corporate paradise
27
I get so confused by Rockwell's licensing structure. I have two PC's that will be running the same SE application. Can/should I run this as network station? Would network station decrease overall traffic to the PLC vs two instances of local? Was planning on buying two licenses of SE station and running each as local, but thought I'd ask first. Thanks!
Local applications
Everything runs on a single PC. Client, HMI Server, Data Server, and the FT Directory (local). You can have remote OPC Data Servers. But otherwise, everything is on the same PC. If you want to use FT Historian, it also has to be on the same PC.
Network Station
Still just one HMI Server and one HMI client that are on the same PC. They cannot be remote. But you are now using the FT Network Directory so the Data Servers, Historian, and FT Directory can be remote. If you have two separate applications, they can share the Data Servers and Historian and users would be shared as well.
Network Distributed
Clients can now be remote. One applications can have multiple HMI Servers along with multiple Data Servers. All items can be distributed as needed to one or more PCs.
Sounds like you really want a single network distributed application possibly broken up into separate areas. All the clients can then talk to the same application. Plus you don't have two separate applications hitting the data servers for data.
OG
Local applications
Network Station
Network Distributed
OG
OK, thanks for the clarification. So basically the only way to get remote clients utilizing and editing from a common location is to buy a server license... I'll probably just get two copies of station and keep it simple for this project.
Network distributed is the most convenient since you don't have to manage two separate applications. Any changes you make only have to be made one time. And you can edit form any PC that has Studio. You don't have to edit from the server machine
And yes, that is the only type that allows remote clients or editing.
OG
https://imgur.com/a/kKPtzyP We are making improvements to these motor controls by replacing these old resistor banks and DC generator with DC...
1,788
Good Afternoon , I'm sorry. But I'm struggling to understand this combination of integers in this MOV , and really anywhere else this scheme...
1,600
Hi folks, I am wondering if you guys can help me understand what the intended operation was for some logic that relates to the operation of the...
1,633
Good afternoon, I want to understand this old piece of logic I found in an old program (RS Logix 500 on SLC 5/03). I have two rungs here in a...
3,652
Hello guys, PLC 5 guy here who recently took a course through automationtraining.ca for some basic understanding on how to navigate through...
2,411
