Vijeo Citect and SMS Server
oko
Aug 2009
Skala
Hi
I´m new in this forum :-D
I´m about to set up a Vijeo Citect Scada system together with a Schneider Electric Premium PLC. I will need a SMS Server that is able to acknowledge every single alarm etc. a "Pro-version".
My questions are:
1) Which GSM-modem do you recommend, a ethernet-modem or rack-based for Premium modem?
2) Which SMS Server software do you recommend? The SMS Server software must control at least 400 alarms!
Thanks!
Have a look at ScadaPhone - Citect recommend it. It comes with a landline modem if my memory serves me correctly. Biggest problem is finding a proper modem (not USB) with a driver for Vista - I have not found one yet. ScadaPhone will work with GSM I believe.
Have a look here
http://www.scadatec.com/index.php
if you couldn't solve your problem or other all solutions is not ok for you . write me an e-mail I think I can solve the problem .
I have developed an OPCServerSMSMAILEngine software for all scada .
[email protected] .
You may try U.C.ME-OPC from Control See. It connects to any OPC or DDE server. You may download a fully functional evaluation version.
Recommended modems:
Cinterion: TC35, MC35, TC65
Wavecom Fastrack
MultiTech MultiModem
Teltonika ModemCom
Michael
Hi - I need a SMS server for sending alarms from Vijeo Citect project (750 alarms) to GSM mobile phones. I´ve found Scadaphone and smsserver 3.0...
6,892
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
68
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
490
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,689
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
900
