Programming an 315 2DP, connecting with an OPC server, Testing a c++ app!!
hlvas
Sep 2010
Thessaloniki
To anyone that is interested to share his experience,
Hi, I program c++ for years, but in PLC areas I am completely unfamiliar, so please bear with me.
ok now to the task in hand. I have a c++ application that needs to be connected to an OPC client an get some data from a PLC through an OPC server.
what I have in my lab: I have a SIMATIC S7 SDK V5.3 + SP2 + HF1. I also installed the S7 lite, a CP5611 card, MPI cable and a SIEMENS 315 2DP CPU (only the CPU nothing else).
In oder to accomplish the task above I thought to make a test app to test the connectivity of all above items. So I am planning to use the SIMATIC OPC server and the OPC scout that comes with it. I am also planning to write a small program to the 315 that the only thing it does is changing some values, so I can verify that these values are correctly read from the OPC server and client.
What I have done so far: I have successfully connected with the 315 through the S7 lite SDK using MPI. I have also read the excellent document of Jesper M. Pedersen and I have set up the OPC server and the OPC scout from SIMATIC S7.
and now to the questions:
1. Basic PLC programming. How I can set and reset a couple of bytes in the PLC ( as I said I am totally unfamiliar, but willing to learn :) ). I want to use a counter so that after N seconds change some bytes to lets say 0 and 255 and then repeat.
2. What have to do to pass these values to the OPC server,so that OPC server can read these values regularly
3. What have to do to pass these values to the OPC scout so that these values are also passed to OPC scout.
4. Some general remarks about how connect a c++ app with the OPC scout.
You do not have to answer all of them :). Any comments hints references books, will be greatly appreciated.
2. Nothing. Your app polls the data from the PLC.
3. Create a connection in the OPC scout. Then add Items (Adresses in the PLC) to the connection. That is all.
4. This site is probably the best: http://www.opcconnect.com/.
Apart from that, you app shall connect as an OPC client to the OPC Server.
The OPC Scout is an OPC test client. So it has nothing to do with your app.
Hi Jesper,
Thanks for your reply.
Two quick questions:
1. Shouldn't OPC scout be able to list the variables automatically. Do I have to add them manually (e.g. like Connections->\S7->@LocalSERVER->objects->DB->DB1->Define New Item). The reason I am asking this is because I have read a SIEMENS article http://support.automation.siemens.c...lib.csinfo&lang=en&objid=17413251&caller=view That OPC scout was able to list the variables in the \SYM directory, which in my case \SYM is listed with an X.
2. When you say add items (Addresses in the PLC) in which addresses are you referring?. For example in my case I have a variable (REAL) in my DB1 table that is in the address +2.0. Is this the address you are referring?
Regards,
Vasilis
PS. I am planning to write a small documents about all the issues, I faced during my understanding of PLCs, STEP 7, configuration.... Taking about the Chicken and the Egg here :).
1. In order to get the symbols from the STEP7 project, you have to have an integrated project with both S7 PLC and PC Station with OPC Server.
The connection from the OPC Server to the PLC must be fully specified.
And you must set the option "Use Symbols" in the setup of the OPC Server.
2. Yes, if you dont have the symbols, you have to add them by yourself. You can browse for the available addresses in the PLC. You will get a list of the DBs. But you have to specify the exact byte address and type yourself.
Hi Jesper,
I am in a deadlock here. I tried to follow your advice. What I am looking is to see the variables of my PLC program to OPC Scout.
I have set OPC server with S7 protocol.I have also successfully connected my 315-2DP with the CP5611 card as the image attached. I have also set OPC Server to "Use Symbols" to all (I tried to use the "Selected" button but the Use symbols in this case is empty which is a first indication that the Symbol table is empty).
I have compile the entire project without any errors. However still in my OPC Scout does not list any symbols.
Am I doing something wrong. Could it be a version problem?
Thanks a lot,
Vasilis
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
168
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
261
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
144
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
982
I need to pull the program off of an old 90-30 so I can convert it to Allen Bradley. This is my first time messing with GE and I don't have the...
101
