Control Techniques Unidrive module UD71 dumb terminal mode?
Zztpokcch
Jul 2014
in the sticks
I have a UD71 serial communications module I'm trying to use to access a Unidrive's parameters, and it claims in the manuals it can do "dumb terminal" mode... But no info I can find goes into any detail on that. Should I be able to connect this up to windows Hyperterminal and get a prompt? (trying it, I get no response from the unit)
Still no luck. I might have a bad UD71, it was off of an old scrap drive...
I was hoping the UD71 would help me change parameter 0.48 from Servo over to openloop mode, and it's not letting me do it from the keypad, even though I put "1254" into parameter 0.00, which is weird because the other undrives let me do it that way. Maybe a software-revision issue? ("1253" in par 0.00 did nothing either)
Why not just use their free software? CTsoft is still available: http://www.emersonindustrial.com/en...serguidesandsoftware/Pages/softwaretools.aspx
'Dumb Terminal' is probably Modbus RTU, since that's what most of the current models use...
UD71 use ANSI protocal
You need Software Unisoft to connect with PC
You must enter 149 in 0.00 then M to change the parameter
Looking for a Modbus address manual for M700. Modbus address is same as the Parameter number for 16Int parameters. But it is different for 32Int...
2,019
System: Drive: Control Techniques - Unidrive SP (Panel Mount) Controller: NI cRIO Power: Whole system runs off of a 3 phase 480V plug. There is...
4,697
I'm looking for a manual on this drive, but does anyone know how to set the slave address? I have a customer attempting to talk to drive with...
5,865
Has anyone experience with Control Techniques Unidrive SP with profibus communication module? Is it possible to download parameters by the...
3,413
We have an EN214 base drive fitted with an FM3 module that has started to drop out of its program at random and then start again after a few...
1,162
