I have a customer who has two HMIs (we'll call them HMI1 and HMI2) which each control an area, and the two areas are right next to each other. They would like to combine both HMI program screens into one program and have the combined program run on both HMIs (each will have a different start-up screen, so technically there would still be two programs specific to each HMI). This is so that if, for example, HMI2 dies, they can press a GoTo button on HMI1 main screen which will then GoTo display for the main screen of HMI2 program, which can then access the remaining screens for HMI2 (and vise-versa). They will still operate like individual HMIs, with all of the screens only accessible from their original program's main screen.
I am wondering if there is a way to filter alarms depending on which "program" they are viewing, and/or with a PB (PB1). Say they are viewing HMI1 screens, and want to view HMI2, they press the GoTo button on the HMI1 main screen and it takes them to the main screen of the HMI2 "program" (this main screen will also contain a GoTo button to go back to the HMI1 main screen) and can then access all HMI2 screens from the HMI2 main screen. I would like to filter the alarms based on which "program" they are viewing. If they press PB1, it will display alarms for both "programs". PB1 will be available on both Main Screens.
(I am putting program in quote, because at this point, they are not separate programs, they are combined into one)
The functionality needs to allow:
- Access either HMI program from either HMI (without having to go to Config of HMI and load/run different program)
- If both HMIs are in good shape and running, and operator wants to switch back and forth between the two "programs" (say, they're too lazy to walk over, or whatever), or the operator is only viewing the "program" for that area, alarms will only be displayed for the "program" that they are viewing (PB1 = 0)
- If one of the HMI dies, the operator wants to switch back and forth between the two "programs", but display alarms for both (PB1 = 1)
I am aware that SE has this functionality, however, I would like to keep it as ME.
Any suggestions would be greatly appreciated!
