C3.1 and CCW Structure Tags
MATT116
Dec 2009
Dallas, TX
330
CCW V11.0
RedLion Crimson 3.1 Latest build
Micro 850
Ethernet
Using the "Allen-Bradley Micro800 Master" driver in C3.1
Guess you can't access tags in a "Structure"? Or am I missing something?
The only work around I see would be to map the structure tags to MODBUS. :confused:
Ethernet/IP Micro800 explicit messaging protocol comparing with CLX has some limitations, structure members can't be accessed, also it doesn't support multiple tag reading in a single request.
I think you should reach out to Red Lion.
We use the maple system (About 4 different models that we use) and several of the Panelview models, all without any problems accessing tags. All with the Micro820, 830, 850, 870.
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
63
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
226
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
169
I am new In a CCW and as a beginner I am trying to learn programming but i am noticing that my CCW software is taking around 1 minute to download...
102
