Viewing STEP5 in Ladder logic: Software
edward4444
May 2006
New Hampshire
I currently have Siemens STEP5 software (V7.2) for use with an old S5 PLC. Recently, the company purchased non-Siemens software that was supposed to give a Windows interface to the DOS-based software.
It does provide a Windows environment...however... this non-Siemens software ("PLC Workshop") is supposed to allow viewing the code in both STL and LAD.
Yet it will NOT show the code in LAD, because the original statement list code was not written in a way condusive to being shown in ladder.
The logic is capable of being expressed in ladder (at least on paper), but the software is not capable of doing so.
Is anyone aware of a software application that can translate statement list from STEP5 into ladder logic?
Even original Siemens software will not translate all STL in LAD is the code is not 100% compatible. Sometimes you need to use 'nop 0' instructies in order to switch to LAD but then the scantime will increase. Try to program a timer in LAD, do not use the outputs and translate to STL.You will see 3x 'nop 0' for the outputs.
I can do it for you. Or you can attend my presentation at the Siemens Summit in Las Vegas June 5 - 8, where I will be doing a presentation on "Migrating S5 and TI PLCs to S7". At the end I am going to show how to convert to S7 and some of how to convert STL to Ladder. If you are interested in me doing it for you, drop me an email.
http://www.sea.siemens.com/summit/home.html
Pg 2000
We use PG 2000 here at work. It will translate STL to Ladder even if it is not written correctly and will not do so with Siemens software. It does not care about the "NOP 0." With that said if the instruction can not be translated from STL to Ladder, it will not do it also. Below is the link to there website.
http://www.process-informatik.de/
They have a demo that you can download from there website that will help you out. Also this software works with both S5 and S7 PLC's and is windows based. They also sell a usb cable for use with the S5.
WOW! lhughes39 Thanks, I don't like the way it looks but thats a very good tool, I have finaly started getting used to STL but this will help on some of the big ladders, thanks again
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
127
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
380
When I added device Powerflex 525 to my project,The ( current tag) was not populated .How can I retrieve this data ? Thanks Jeff
555
Hey all, looking for some opinions/recommendations for Modbus server viewing software. Have a PLC that we're reading directly from the modbus...
1,901
Seeking ideas here. This is not really VPN access but just to let someone have view-only access to local HMI screens on their phone from...
3,782
