Powerflex 525 viewing Current on Panelview 7 plus
Kantzje
Apr 2015
PA
When I added device Powerflex 525 to my project,The ( current tag) was not populated .How can I retrieve this data ?
Thanks Jeff
What tag are you referencing in your PanelView project, I believe you need to use N registers to get data from the PF525.
There is a TechNote on how to communicate and control the PF525, I will see if I can find it.
TechNote is QA52360, you will TechConnect to view it.
It sounds like you need to add OutputCurrent as an input in the drive definition. In the old days they called it Datalinks. Now I think it is just called Inputs and Outputs. The 525 definition in your project will need to have that declared. The drive itself will also need a parameter set to match that.
You can also use a MSG instruction to grab the Output Current as well.
Not sure on the exact MSG attributes, but a quick search should provide you that information.
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
236
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
247
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
480
Are the N files in the 525 the same as the 40p for ethernet? (E-Comm card) I have used 40P with Micrologix 1400 Messaging but don't see the N...
238
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
303
