Windows 10 1903 VMWare issue?
JZerb
Oct 2016
Here
423
So my host machine which runs Windows 10 is wanting me to upgrade to 1903 OR ELSE. When the machine tires to update it gives me an error saying that VMWare will not run on the updated OS so i need to fix that first before updating. Then i go online and see that VMWare Workstation Pro any version under 15 JUST DOESNT WORK on this new Windows 1903 update, not really new i think it came out around May.
Anyone else have this issue?
I don't have my workstation with me so can't check versions but...
My host is updated to the latest updates and the 4 VMs (Win7) I have all seem to work. I even updated my personal VM Win10 to the latest and everything seemed to be working as well.
Any clues on what you mean that it just wont work? Like, the VM no longer boots? I'm not sure how seamless upgrading VMware is but 15 doesn't sound like the latest version (but I can't check what I'm running right now).
I'd recommend backing up all your VMs to the current state and then give it a go.
Yeah we had this issue. Previously we worked with Version 11 and with the new 1903 update, every VMWare version below v15 is incompatible. So the only solution is to get a license for v15 if one wants future Windows updates.
JZerb, In a pinch you can do Start-->Run-->GPEdit then go to Windows Components--> Automatic Update --> Disable Automatic Update and set it to "Disabled", then click okay on it all. This will buy you some time in a pinch, but I do not suggest doing that.
Now, as for the update. here is a thread on the various issues. Right at the top, one post mentioned switching the adapter from Bridged to NAT to boot up, then switching them back and having to do that at every boot.
https://communities.vmware.com/thread/608589
Also, from the last page of that post:
I got VMWare Workstation pro 15 working on Windows 10 1903 by removing hyper-v. You cannot have hyper-v installed because VMWare uses it's own hypervisor which is not compatible with Hyper-V. Windows 10 version 1903 installs hyper-v to run sand box and containers. These feature create a virtualized environment to prevent malware from being able to corrupt or control the host operating system. So when you uninstall hyper-v, those services will not be able to run.
I uninstalled Hyper-V. Go into programs and Features, then Turn Windows features on or off. scroll down and clear all the checkboxes under hyper-v. Then I had to reboot. Initially I could not open programs and features. I waited about 5 minutes and rebooted again. Eventually I was able to run programs and features from the control panel. I selected VMWare workstation. and clicked change to repair the installation. It required me to stop VMWare.exe, so I killed it using task manager. Then I chose repair installation. waited for it to finish and rebooted again. After that VMWare workstation pro 15 was up and running.
If you don't need Workstation Pro specifically, Workstation Player 15.1.0 is working with the 1903 build.
That’s what I read as well. The only fix was upgrading to version 15.
Thanks! That sounds like an absolute pain in the *** compared to having to pony up $150 to upgrade from version 14 to 15. My issue is, what happens if the next Winblows 10 update makes version 15 unusable? Seems like quite the scam to me.
Oracle Virtualbox VM free version runs fine on my 1903 Windows 10
I run Simatic v5.5 on it
For those who do not want to pay $150 and more in the future, switching over to Virtualbox is very easy and painless.
VB will use your vmdk file from VMware.
Really? That i didnt know. That may be a route I try. Thanks!
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
56
Hi everyone, I have an issue with installation of Studio 5000 33.00.02 DVD Media disc 2 with View Designer on Windows 11. After installation...
126
Hello all, Hope everyone enjoying their weekend. I just recently bought a laptop to upgrade my old one with i3 its getting slow on me. But when i...
439
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit...
348
Hi all. I received two identical brand new Dell desktops from a customer to install the softwares for a project. The first one is for a...
538
