Panel View Plus 7 Performance & Windows 7
RRY
Dec 2023
Horana
I want to run a factory talk view ME project in a Panel View Plus 7 Performance HMI. The project was developed in a 'Windows 7 Professional 64 bit Operating system'. Is it possible?
In HMI user manual I found below
Microsoft® Windows® operating system:
• Series A (and Stainless Steel Series A and B): Windows CE 6.0
• Series B (and Stainless Steel Series C): Windows 10 IoT Core
In general, an MER file will run fine on a PV+ as long as it was compiled for the correct type of HMI (compact, standard, performance, etc.) and the firmware version of the HMI is at least as high as the compiled file. The OS of the development PC shouldn't matter. I say "shouldn't" because it's certainly possible to be a problem but in my experience it doesn't matter. As long as the MER file is correct for the target device.
That information in the manual looks like it's for the OS running behind the scenes on the HMI itself.
As long as you can run FTME version on your PC and create the .mer, OS doesn't matter. I use Windows 7 virtual machine for FTME versions 8 to 12.
I'm going to highjack this a little bit but in order to have multiple FTME versions, each one has it's own VM correct? I think that goes the same for FTSE?
You can have FTME and FTSE (Factory
Talk View) coincide, but yes, I have separate VMs for each version.
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
281
Good morning, I have a question, I would like to know if I can send an Excel file to an email from my panel view and see how it is possible to...
157
I purchased a used PanelView Plus 1000 to learn get familiar with the software. Seems to be a pretty popular HMI. I can ping the HMI but I cannot...
886
Hello, hope yall are doing well. I have a HMI program where I need to add a "GoToDisplay" button, so when this button is pressed, it goes to a...
887
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
924
