Lamboom
I spent quite a bit of time researching LinMot Linear Motors, after it was suggested, on this forum, that they would be the best actuator for my project. My project required operator initiated, position control, following mathematically generated curves.
LinMot produces a wide verity of Driver/Controllers to manage their motors. Most differences are related to communication methods, Ethernet IP, Profibus etc. LinMot tends to prefer Rockwell PLC's and the RSLogix 5000 software. Siemens PLC's will also work, using their Professional TIA Portal software.
I'm curious what others on this forum may have done, that was simpler .. or at least cost effective.
The title above says "manually" .. suggesting an HMI, because there is no automation going on here. All start/stop control must be done by an operator. It doesn't have to be by HMI(Closed Loop), a touchscreen could be used, communicating with a PC. The PC produces an analog signal (DAC), which inputs to the LinMot Drive,... and thus, the "position" is controlled (Open Loop)
About a year ago, Peter Nachtwey (pres. Delta Motion)suggested on this forum, that I use a motion controller, and an advanced HMI.. like the Red Lion G3 series. I was slow to appreciate that suggestion, and continued to slog thru the ever-entangling difficulties of making a PLC do the job.
Eventually, I saw the light .. and now have a wonderful system (PLC free) that can do anything with the LinMot linear Motor.
I'm curious tho .. This is a forum with vast experience in Automation Engineering ... So, I'm asking what do you think?
Could you have built something using a PLC and HMI, other than Siemens and Rockwell ... and not needed expensive programming software?
Regards, Michael
Regards, Michael
