Ladder logic displayed on HMI
ValeoBill
Aug 2019
Wasaga Beach, Ontario
87
Hello, all;
Years ago, I worked with an HMI on which one could display (read only) the associated PLC's ladder logic. If memory serves it was the GOT/GX developer of Mitsubishi construction. I thought it a great idea for pinpointing problems without the delay of getting online with a laptop.
Has anyone else come across this feature on other platforms?
Siemens can do it with 1500 & Comfort/Advanced HMIs with a feature called ProDiag (extra license required). It covers LAD, FBD, and Graph.
The OMRON NSJ range had this feature. I used quite a few of them back in the day around 2005-2012.
Hello, all;
(Fuji) Hakko.
I have seen this on some machine tools with a fanuc Controller.
Same here is was a CNC machine... great idea for troubleshooting, the only thing I have ever done was a maintenance screen that had the most problematic I/Os listed and they just had a little light next to them, I did install RSLogix on the same PC that was running RSView and that was nice but it was not a read only
The new Mitsubishi Got range have that facility, Beijers E Series was the HMI Mitsubishi adopted (re-badged)from the 90's until about 2010 and I believe these also had this.
Rockwell had an Active X control that would do that for RSlogix500
i used it in a few projects it allowed you to display the ladder in real time on line so you could watch the data state change in your HMI
i even had it set up with my alarm panel the operator could push a button on the alarm screen and it would open a window to show the ladder at the alarm
it was great for trouble shooting
but it required RSLinx on the host to run
also ActiveX is no longer supported
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
155
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
197
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
419
Working on project will update after it is completed.
355
Can someone help me piece this problem together. I have a lot of it down I think but cannot seem to get it right. Probably an easy one for most on...
303
