MultiSmart to Wonderware protocol conversion via RedLion
deltahfturbo
Sep 2012
Napier
Hi guys,
I've just self taught myself both Modbus and RedLion. I was wondering if someone could have a look at what I am doing with RedLion protocol conversion to ensure I am on the right track.
Essentially what I have is 5 MultiSmart pump controllers connected to a RedLion DLE via RS232. I am satisfied that this has been configured correctly. I then want to pass the same set of data points from each to my Archestra SCADA project via DASMBTCP. The MultiSmarts are all configured and the SCADA is proven on sites which have direct MBTCP comms. The image below shows my configuration thus far for the RedLion.
http://imgur.com/gBN66
My thinking is that the 5 MultiSmarts are Modbus slaves to the RedLion (RedLion is therefore Modbus master), whereas the SCADA is a Modbus master to the RedLion (RedLion is therefore Modbus slave).
Assuming the 5 MultiSmart protocols have been configured correctly it is simply a matter of creating gateway blocks on the RedLion to pass the MultiSmart data straight through to the SCADA. It is not necessary to create data tags within the RedLion. I have therefore created 4 gateway blocks (Digital Coils, Digital Inputs, Analogue Inputs and Holding Registers). Each of these gateway blocks has enough elements to account for all the Modbus points within each of the same register type in all of the MultiSmarts.
Does this look right to you guys?
Kind regards,
Chris
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
142
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
101
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
181
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
174
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
156
