Linmot Time Curves
OtterSpectrum
Oct 2014
Canterbury
Greetings All.
I am attempting to use a Trio Motion MC403 controller (with code written in TrioBASIC) to talk to a Linmot E1100 drive the via LinRS protocol.My Trio program creates a custom curve and downloads it to the Linmot, storing it in RAM with curve ID 1.
If I store this curve in FLASH, I am able to use Linmot Talk to run the curve, so I know that it has been formatted properly.
The problem is that if I attempt to run the curve from the Trio program, nothing happens. The command I am sending the Linmot is "time curve with default parameters (040xh)", and the relevent code is:
Code:
[COLOR=#800000]PRINT[/COLOR] [COLOR=#0000ff]"--- home linmot ---"[/COLOR]
[COLOR=#800000]SETCOM[/COLOR]([COLOR=#000080]57600[/COLOR], [COLOR=#000080]8[/COLOR], [COLOR=#000080]1[/COLOR], [COLOR=#000080]0[/COLOR], [COLOR=#000080]1[/COLOR], [COLOR=#000080]0[/COLOR])
[COLOR=#008000]' Error acknowledge.[/COLOR]
[COLOR=#800000]PRINT[/COLOR] #[COLOR=#000080]1[/COLOR], [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]5[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]2[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]191[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]4[/COLOR]);
[COLOR=#008000]' Request default response.[/COLOR]
[COLOR=#800000]PRINT[/COLOR] #[COLOR=#000080]1[/COLOR], [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]3[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]2[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]4[/COLOR]);
[COLOR=#008000]' Clear lock state.[/COLOR]
[COLOR=#800000]PRINT[/COLOR] #[COLOR=#000080]1[/COLOR], [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]5[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]2[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]4[/COLOR]);
[COLOR=#008000]' Enable and home.[/COLOR]
[COLOR=#800000]PRINT[/COLOR] #[COLOR=#000080]1[/COLOR], [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]5[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]2[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]63[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]8[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]4[/COLOR]);
[COLOR=#800000]WA[/COLOR]([COLOR=#000080]5000[/COLOR])
[COLOR=#008000]' Normal operation.[/COLOR]
[COLOR=#800000]PRINT[/COLOR] #[COLOR=#000080]1[/COLOR], [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]5[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]2[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]63[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]);[COLOR=#800000]CHR[/COLOR]([COLOR=#000080]4[/COLOR]);
[COLOR=#800000]PRINT[/COLOR] [COLOR=#0000ff]"--- play curve ---"[/COLOR]
[COLOR=#008000]' Time curve with default parameters.[/COLOR]
linmot_telegram = [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]) + [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]) + [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]5[/COLOR]) + [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]2[/COLOR]) + [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]) + [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]4[/COLOR]) + [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]1[/COLOR]) + [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]0[/COLOR]) + [COLOR=#800000]CHR[/COLOR]([COLOR=#000080]4[/COLOR])
[COLOR=#800000]PRINT[/COLOR] #[COLOR=#000080]1[/COLOR], linmot_telegram;
I am convinced the problem lies with the time curve command, as if I replace it with a predef VAI command, the acutator moves as expected. Is anyone familiar enough with Linmot drives to tell me what I am missing?
After great help on the forum getting a Red Lion G3 HMI to control & communicate with Advantech's ADAM-4055 D/IO modules, the next step was to...
4,355
Thanks to many people on this forum, and automation engineers in in several countries, not evolved with this forum, I have been able to almost...
2,009
Hi Guys Any of you guys have a idea how to read the on the PLC ( Omron NJ my case ) errors from Linmot , I have a C1250 Drive Ethercat...
1,897
I spent quite a bit of time researching LinMot Linear Motors, after it was suggested, on this forum, that they would be the best actuator for my...
2,997
Below, is the specs for the IO’s for an old LinMot Servo Drive NOTE: With the I/O supply connected at pins 8 & 21, If I test the Input (pin 4)...
1,296
