Lamboom
Below, is the specs for the IO’s for an old LinMot Servo Drive
NOTE: With the I/O supply connected at pins 8 & 21, If I test the Input (pin 4) “Enable", .. controller is not connected yet, by touching pin 4 with 24VDC, the “Enable” indicates “True" on the Driver software. Confirming the below text on digital Input.
Unfortunately, the Drive also issues a Warning.. "over current”. Might be I’m exceeding 20mA using using 24VDC?
As shown below, I need to connect the IO’s between a Delta RMC75E Controller and the Drive .. NOTE: LinMot shows only ONE wire to pin 4
