I/O's Hurt My Brain (Delta vs. LinMot)
Lamboom
Mar 2014
Fallbrook, Ca
350
Below, is the specs for the IO’s for an old LinMot Servo Drive
NOTE: With the I/O supply connected at pins 8 & 21, If I test the Input (pin 4) “Enable", .. controller is not connected yet, by touching pin 4 with 24VDC, the “Enable” indicates “True" on the Driver software. Confirming the below text on digital Input.
Unfortunately, the Drive also issues a Warning.. "over current”. Might be I’m exceeding 20mA using using 24VDC?
As shown below, I need to connect the IO’s between a Delta RMC75E Controller and the Drive .. NOTE: LinMot shows only ONE wire to pin 4
(1) Here’s the Question: From this picture… I’m guessing the top diagram (High = Enable) applies to my setup. Enable out (-) would run to pin (4) with a 10 K resistor between common Pin (21), and Pin (4) … and, Enable out (+) would connect to Pin (8) … The 10K protects the SSRelay. Am I correct?
(2) And.. Here’s a silly question … The “Enable" wires: (Beldon) are (+) Orange/White, and (-) White/Orange … I am assuming that means (+) is a Orange body with small White spots, and (-) is a White body with small Orange spots? This convention is not given in the diagram… sigh!
Sometimes wires have body colors with a thin colored stripe. These have body colors with a colored spot about every inch.. I’m assuming (because I’ve failed to find the convention on the web… ) The first color is the “body” and the second is the spot or stripe? Am I correct?
Thanks much .. Us newbies working in a cave far from other humans who know anything about the electronics of motion control, must grovel and snivel for guidance .. it’s much appreciated. Regards, Michael
You can hurt yourself and others, so watch the intake. I got this off of the Food channel last week...damn it's good 3-4 chicken breast Triple...
3,465
Take a look at this program. The add part works fine but when I want to subtract the subtract subtracts about 3 times. Any idea why? All of the...
3,125
Back in the old days of ProfiBUS, I used to use this little adapter card that plugged into my laptop, it was like a compact flash card but taller...
1,621
I'm event AV Technician (Sound, Projection, and Lighting). Over the last couple of years I've used a Weigl ProCommander PHX to control some event...
2,752
Hello, I have some EVAP units that use an an OPTO 22 SNAP-PAC-EB2 Brain to control I/O. I downloaded the latest basic software package from OPTO...
1,717
