siemens s5 + s7 on ethernet want acess each plc program via modem
dbolton
Oct 2004
preston lancashire
hello
Currently have 4 x s7 400's and 3 x s5 115u's all conected via coms cards to ethernet going back to a scada.
What I need to do is find the best or most pratical way of being able to get online to each plc via a modem from a remote site.
Can I do it through the ethernet or do I have to do it through each individual plc's programing port.
Would appreciate any info on ethernet and conecting to plcs via modem and about any special siemens cards that could help us out
134
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
179
Can I open a Port from a Siemens PLC to an ethernet device Device will be at 192.168.0.1 and I need to open port 2112 (Upd?) Then once the...
311
372
Hello, I want to communicate controllogix PLC 1769-L33ER with S7413-3PN/DP using there elthernet connection. So how we can do this? Is any devices...
18
4,895
