FTView ME Audit Log
robw53
Nov 2009
south yorks
515
I'm looking to create a method of logging changes in set points on Panelview Plus series 7 HMI's and letting Asset Centre store them. I see that they have an audit log when you set up electronic signature on buttons. I won't be using the standard factory talk security I will be using RFID fobs for each user and compare the ID against a database stored in the PLC. Is it possible to modify the audit log so that it points to a user outside of the FT security and logs that information for the user?
If this isn't possible, what are my other (ideally Rockwell) options? Historian, Transaction manager?
Regards
Rob
I am trying to Implement RA's 21CFR11 Audit Feature for View ME stations using Asset Centre. The feature has been working as expected, however my...
1,980
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
169
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
214
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
87
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
86
