robw53
I'm looking to create a method of logging changes in set points on Panelview Plus series 7 HMI's and letting Asset Centre store them. I see that they have an audit log when you set up electronic signature on buttons. I won't be using the standard factory talk security I will be using RFID fobs for each user and compare the ID against a database stored in the PLC. Is it possible to modify the audit log so that it points to a user outside of the FT security and logs that information for the user?
If this isn't possible, what are my other (ideally Rockwell) options? Historian, Transaction manager?
Regards
Rob
Regards
Rob
