vacuum transducer greater than -14.5 psi
There is no true "Absolute Zero" in pressure...a perfect void does not exist... yet.
Perhaps the other side of the "Event Horizon"
The OP did reference vacuum, usually measured in inches of mercury (Hg)
The OP is putting it on a vacuum pump. I don't think he needs a Magnetron, Pirani, or thermocouple. A digital gauge like this one should do. Don't forget the bracket. Rescale for INHG, and put the tiny sticker on the window. Use 2 wrenches when attaching the vacuum fitting.
This is on the suction side of a vacuum pump.
What is the vacuum pump used for?
There are many different types of vacuum pumps covering many different levels of vacuum required.
Mfg and Model number?
Using PSIG may not be enough readability or correct for your application. Some vacuum pumps have ultimate ranges of around 10-3 to 10-4 Torr (or 1 micron), which is below gauge pressure, which is based on Atmospheric pressure and not Absolute pressure..
Here is a link to a conversion table and you can see where psig more or less disappears.....including inHg..
url
The OP may have been confused by the gauges used in refrigeration. When you evacuate a system, you want to pump it down to "28 or 29". At first glance, it's not clear that the negative side of the dial is in Inches of Mercury, not PSI.
url
Oh dear god. You 'mericans do make me laugh sometimes. Why use a single SI unit for pressure, when you can use both pounds per square inch, and inches of mercury to measure the same thing, combining three imperial units and a toxic metal instead? :ROFLMAO:
I'm working on a project using a Micrologix 1100. Im having trouble locating a transducer that will measure vacuum and has a 0 to 10V DC output. I...
6,692
For part of our test system, we need to measure water level inside a chamber, which is under vacuum. We were successfully using one of these by...
112
28,178
Good afternoon all, does anyone recommend any coolant vacuum filter pumps to clean out tanks and get all the sludge and chips out of a...
2,983
Hello guys, how do you clean dust in PLC cabinets? Do you use industrial vacuum cleaners, compressed air maybe or something other? In most...
1,688
Hello, If you need to dump the air to allow someone to enter the cell, how do you handle situations where the vacuum is still holding something...
2,670
