Coolant Vacuum Filter Pump for Self-contained coolant tanks?
alive15
Oct 2015
Montgomery, AL
721
Good afternoon all, does anyone recommend any coolant vacuum filter pumps to clean out tanks and get all the sludge and chips out of a self-contained coolant tank unit? I've been eyeing these two with different price ranges, but wanted to check with the community here and see if there is a better one out there?
$1700 option from Exair - https://www.exair.com/index.php/products/industrial-housekeeping/chip-trapper/ctr-sys.html
$5000 option from Cooljet - https://www.youtube.com/watch?v=Ugup6VuaHgA&ab_channel=ATSSystem,LLC
Seems like the $1700 requires a filter bag and a 30 or 55 gallon drum, while the $5000 has a steel bucket that catches everything and immediately places the clean coolant back into the tank.
If anyone recommends one of these two or another system from a different mfg, that would be great. Please share any experiences you have.
Thanks!!!
Hello guys, I am designing a liquid dispensing system for CNC machines that will top-up a mixed solution of coolant & water at the required...
2,307
For part of our test system, we need to measure water level inside a chamber, which is under vacuum. We were successfully using one of these by...
112
28,187
Hello guys, how do you clean dust in PLC cabinets? Do you use industrial vacuum cleaners, compressed air maybe or something other? In most...
1,693
Hello, If you need to dump the air to allow someone to enter the cell, how do you handle situations where the vacuum is still holding something...
2,674
We got a quote from a vendor of some chlorine equipment but it is pretty expensive. ($525) It appears to be a UE brand vacuum switch with an...
2,193
