PROFINET software stack
ekrem03
Jun 2013
new hampshire
I have a project to communicate with either PLC or HMI through PROFINET from my microprocessor. I have designed my Ethernet hardware and now I am looking for a free PROFINET software stack. I have not found any stack yet. Is there anybody here that could give a tip here?
I am also providing a Profibus communication and for that the ASIC chip (from profichip) came with the software stack. For Profinet I couldn't find any IC to use, for now I am planning to use microchips ENC424J600 for the ethernet interface and find a software stack that could help me to communicate to a PROFINET machine.
Baranyk: Renesas chip looks like a solution for me. From my understanding is it a stand alone Profinet interface with Profinet-SPI to the microprocessor?
JesperMP: These are pretty costly for my application process right now.
To be honest, I'm not entirely sure how it works... I haven't worked with it. But I do know it forms the basis for a lot of Profinet-based systems...
My company has implemented the ProfiNet stack from Molex and got it certified. Yes it costs lots of money but it is worth it if you consider how long it will take to write the stack yourself..
The ProfiNet stack is HUGE!!! It is bigger than all the other protocols put together. Formerly that title belonged to Etherent/IP.
I think your best option is to find the stack already implemented on a microcontroller or module that you can interface your project to.
Profinet is not a low cost protocol.
Hello! I haven't worked with software redundancy before, so I was wondering if I could use the CP343-1 Lean modules (which I'm using for the...
1,779
344
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
467
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
788
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
352
