Profinet Network Setup across Different Subnets in a Plant
Guys I have another question I'd like to clarify. From what I understand, connecting a Profinet IO device like a weight transmitter to the PLC across different subnets via routing might not be possible. However I'm wondering if it's possible to connect a computer running SCADA (WinCC Unified) to the PLC if they're on different subnets. I believe this connection doesn't rely on the Profinet protocol, does it?
There are ways it COULD be done in your situation, but yes routing Profinet is definitely not one of them. As discussed, VLANs or separate infrastructure are options for PN.
Do the scales support modbus tcp or EIP or OPC UA?
It does not rely on Profinet, it can be routed.
No the scale only supports profinet and profibus.
To get the wincc and PLC to communicate what ip addresses should i assign? The PLC is in the subnet 172.16.102.x and wincc pc is in 172.16.103.x. Although the computers across these subnets can communicate and ping each other as routing has been setup by IT but my wincc and PLC cannot communicate. Btw I have assigned the ip 192.168.0.1 to the PLC and 192.168.0.2 to the wincc PC. When i tried connecting them in the same network (172.16.102.x) they connected and started communicating but not across different subnets. Do I have to use the option "use router" in tia portal?
You need to talk to your IT department who is responsible for the network, tell them what you want to do, and have them tell you what to do.
If the devices are in the same subnet, you don't need to define a router/gateway. If they aren't, you need one. However, you may not be able to pick your own IPs Or settings. You may also need to take things like IT firewalls into account. This is why the IT dept is important, unless you definitely know what you're doing and how the network is set up.
Thanks mate. Appreciate your response
I am using an Emerson CPL410 cpu as a PROFINET master. I don't believe that this CPU supports PROFIsafe, as otherwise it would have been...
2,712
Hey everyone, So I'm adding a new Leuze barcode scanner to an existing Profinet network and I need some help. Below is what I think I need to do...
19
4,844
https://i.imgur.com/DxEkaxK.png (HMI IP is set at the device itself) This is my setup, i have a 315 CPU that controls 17 devices in total. In my...
1,811
Hi, I have a question about the use of router or other system to connect a profinet network with the company's network. Simply explained: I have...
3,589
Hi, please i need information about PROFINET ... Can i use "regular" unmanaged switch for PROFINET network?? I have CPU, with one Industrial...
3,186
