I am using an Emerson CPL410 cpu as a PROFINET master. I don't believe that this CPU supports PROFIsafe, as otherwise it would have been mentioned all over the documentation (however I may be wrong about that)
One of the devices on my PROFINET network is a safety rated Huebner Unit One overspeed switch (UO-SCU-G), (and this next bit is a bit confusing to me) that is supposed to be interfaced to PROFINET via a UO-EPN-2 (which is apparently the non-PROFIsafe interface, I believe that the PROFIsafe one is UO-SPN-1)
The only GSD file that I can find for the this system ("GSDML--V2.3-HU-024A-AMPN(H)41-20150424") includes a fixed set of modules when you create an AMPN(H)41 device on the network. These modules are (leaving out slot 0):
While the "non-safety" slot only has
My questions are:
Previously I have only used U-Ones on PROFIBUS, and I had a lot more confidence in the way the system worked.
Finally I am not in control of hardware design, and that is happening on the other side of the planet anyway. I'm just trying understand what is being asked of me.
- Slot 1 AMPN(H)41 I/O Safety
- Slot 2 AMPN(H)41 I/O
- PS input cam
- PS input status
- PS input velocity
- PS output control1
- PS output control2
- PS output preset multi turn value
- input cam
- input velocity
My questions are:
- How well is this mishmash of PROFIsafe and non-PROFIsafe components going to work?
- Should there be a GSD file somewhere that matches the non-safe UO-EPN-2?
- Is it likely that the inputs marked "PS" will also get populated along with the non-PS inputs?
- Is it likely that the "PS" preset can be sent across a non-PROFIsafe network to the device?
