Profisafe (STO function) between s7-315F and simotion D435-2 - 7 drives
Jun 2016
iughj
Hey,
my problem is :
is there a possibility to establish profisafe connection between S7-315f-PN and Simotion D435-2-PN while using 7 drives/axes. All I need is STO function.
According to siemens documentation:
only 6 axes overall, while maximum 4 drives in 1 drive-cliq line to assure STO in deafult time. What if I will change the time, the max. number of drives will rise? Is there possibility to bypass this problem? Please help.
1) Our encoders have SIN/COS outputs. Heidenhain - multiturn endat 2.1 eqn1125
Anthony
After 6 axis, a simotion D system needs a cx-32 or another cu320.
These control the sinamics part and contain the safety integrated
this is a quick explanation. Also sto does not need a license
I know about the license.
Are you sure about the CX32? Have you read it in any siemens documentation or is it your personal experience? I did not find any reliable source.
Yes. I'm sure
Study what Sinamics is and what Simotion does.
Just because a D435 can do say 32 or 64 axis. This
Doesn't mean you can drivecliq (daisy chain) all of these together
@JRW
Ok, you were right, i found the answer in siemens documentation.
Thank you.
My second question is:
Overview:
We need multi-turn absolute encoders (the choice for now -> Heidenhain - multiturn endat 2.1 eqn1125)
Question:
Is it permissible/possible to active the safety integrated functions while connecting simotion and encoders through endat 2.1 interface or do we have to choose other device?
* @mk42
I just can not argue with that! :D
Hello, I´m doing an exercise in safety and is using SENPDP and RCVDP to accomplish a safe connection between the two PLC:s. But I´m stuck at the...
786
I am using an Emerson CPL410 cpu as a PROFINET master. I don't believe that this CPU supports PROFIsafe, as otherwise it would have been...
2,712
Has any one got any experience with Safe Limited Speed , I've used the standard library functions for the drive safety and standard telegrams...
2,214
Hi, I have a problem with N2 6SE7138-4FB04-0AB0 we have still the comunication error. SF led on. Someone can help me?
1,766
Hello, Does anyone have any experience on configuring S120 with TIA and STARTER. I have 3 CUs. I have made the configuration at both ends, TIA...
3,813
