unmanaged switch for PROFINET network
automat_plc
Mar 2011
america/europe
please i need information about PROFINET ...
Can i use "regular" unmanaged switch for PROFINET network??
I have CPU, with one Industrial Ethernet port which is PROFINET configured, and i need to connect several PROFINET interfaces with I/O cards. So, only for connection mentioned port of CPU and several PROFINET interfaces and nothing else ... can i use "regular" unmanaged switch??
Also my CPU, has second Industrial Ethernet port which is Ethernet(TCP/IP) configured , and serves for HMIs and SCADA, and i also use "regular" unmanaged switch for this and works well.
Thank You very much,
best regards.
automat_plc
It really depends of the amount (and type) of data traffic pushed through the switch; you could get by with an unmanaged switch, however, in time and especially when you start adding to or further developing the system, you might start experiencing timing issues.
Unless you are capable to establish exclusively "unicast" type connections (or segregate I/O traffic from the SCADA/HMI broadcast one) you will need to manage the switching via IGMP Snooping enabled switches (managed type) at least for your peace of mind and your job's professionalism requirements.
Hi, I am looking for an unmanaged network switch (IP67) that can be powered by POE. Any suggestions?
1,707
Other than Allen Bradley. Who else makes EtherNet/IP prioritized switches? I am looking for 5, 8, 12 Port 1000Base (1 gig) Unmanaged Wago and...
1,617
I'm not a network guy, but I play one on TV. So, I can ping my unmanaged switch in the control panel only after a power cycle. The PLC and HMI...
2,579
Have a long rung from PC to PLCs. Bought a X101-1 switch to convert Ethernet (Profinet) to fiber. (X106-1 at PLCs end). The only configuration is...
1,921
we have a cause use 1768-43S CPU as a controller, with one 1768-ENBT as a Ethernet/IP interface. does an unmanaged switch can handle both Safety...
2,840
