IP67 POE Unmanaged Switch
Thanks, the idea was to power the switch with POE without needing a power supply.
Don't know if products like this is available, so just going to use normal switch and power supply
I could not tell you for certain, I took the option PP under power supply as if it ment the switch could be powered through POE. Might have to email/call them to confirm.
On another note, since you are going with IP65/67 which will typically have a coded M12 power connector could you not just make your own cable from your PoE source to the power connector on the switch? Saving you from having to add a power supply?
If it was a test unit, then yes, makes sense, but to install at a client with custom cables is not ideal.
And I think the module we are using is 48V with normal switches using 24V.
why use an unmanaged switch?
it has to receive / transmit data to every port every time.
a managed switch only transmits/receives data from the port when requested.
my experience i that they are much faster, it's all i use.
james
I am looking for an Alarm/Horn Combination unit that will work in a steam environment (i suppose IP67 rated). Has anyone used something like this...
2,490
Does anyone know of an IP67 field-mountable Ethernet switch that supports the Rockwell "Device Level Ring" protocol, but isn't a Rockwell...
1,325
Wondering if anyone has any experience with an industrial mouse that works well and isn't too expensive. Right now looking at the mouse that Hope...
2,224
I've been watching and learning from this website for several years, but this is the first question I've asked. I am looking at networking...
2,195
Dear all. Do you know Operator Panel Support Ethernet/IP and IP67?. I use Operator Panel with Controllogix for ShipLoading oil in Oil Terminal!
3,023
