PvP7 stuck on boot screen
Evirua
Aug 2018
Here
34
The screen stayed the same overnight. I've tried cutting off the power and turning it back on, it just gets back to this screen and freezes on it.
This issue first happened when I downloaded an .mer (ME v10) onto the panelview. Basically the same program it was running, except I'd altered the file path of the CSV Export Setup by taking out the double quotation marks. Not sure how this could affect that.
Anyone went through something similar?
You could try factory resetting it, if you plug in a USB keyboard and cycle the power to the PVP. when it restarts a white square will be displayed on the bottom right corner of the screen press it to open the boot/maintenance screen or press F1 on the keyboard to display it also.
Then reload the application.
The PanelView's Boot Loader is probably attempting a connection with a USB device. The CSV Export you changed, was the export going to a USB flash drive? Also, I believe the double quotes are needed if you have any (spaces) in your file path or file name.
One option you can try is make a boot loader USB flash drive and startup the panelview that way. Here is a link to Shawn Tierney site that should walk you through the process.
https://theautomationblog.com/how-t...usb-flash-drive-script-on-the-panelview-plus/
I was simply exporting to My Documents (In the Panelview's OS), no USB. Thanks for the tutorial, I wasn't aware that was possible.
I was about to do a factory reset; Plugged in an USB keyboard, cycled power to the panelview, and it booted up successfully before I could hit F1 or press the corner square. I still have no idea what caused the problem and what solved it.
If the problem re-occurs, I guess I'll just go through with the factory reset.
Hello everyone, I'm having trouble solving this one and was hoping someone could help. I have a AB CompactLogix L16ER PLC connected to a AB...
583
I have a panelview plus 7,and often popup a messagebox"application servicesd.exe encountered a serious error and must shut down"I refreshed the...
1,068
Hello everybody, struggling to make any sense of what this thing is doing with the time settings. 1. My PLC has a DINT[7] array with the...
3,082
Folks. Iv the luxury of replacing a PVP7 that got hosed down internally this morning. It happens here. I'm used to it. However, today, the...
5,195
I'm working for a customer who would like to replace local authentication on their PVP7 (FTVME 8.00) with Domain Authentication via LDAP. The...
1,865
