Unable to communicate between Versamax Micro and Redlion Data Station Plus
Bilbo1161
Sep 2015
UK
51
Can anyone help me getting this comms connection set up?
I am using Port 2 on the Versamax ICU200UDR005-DK, set in SNP with port settings
Baud Rate 19k2
Stop Bits 1
Parity Odd
SNP ID 1
In the Redlion I am using SNP Master
Comms Settings 19k2
Baud Rate 19k2
Stop Bits 1
Parity Odd
SNP ID 1
Port Set to RS485 4 wire
I have made a cable up to run from the Redlion to Versamax as follows
Versamax 15 Pin D plug RedLion RJ45
7-----------------------------------------6
10 ---------------------------------------8
11----------------------------------------7
12----------------------------------------3
13----------------------------------------4
Using this configuration I cant appear to get any flicker of comms on the comms port indications.
Any help would be appreciated
The meaning of the VersaMax pin designations is not intuitive. They use the terms A and B for polarity where A is - and B is +. If the Red Lion uses + and - to designate polarity it is easy to get them connected wrong. I tend to think positive/negative corresponds to A/B, but that's wrong for the GE side.
I don't have the pinouts for the Red Lion at hand, but that's the first thing I'd check.
So on the GE side:
Pin 10 = Received data -
Pin 11 = Received data +
Pin 12 = Transmitted data -
Pin 13 = Transmitted data +
Red lion connections are
3 RxA
4 RxB
6 Ground
7 TxB
8 TxA
I think that makes the cable connections correct?
Could I be doing anything else wrong?
Hi, i have fx5u plc. Want to communicate with citect scada. Have tried multiple protocol but it's not communicated. Can any one help in this topic.
1,850
Can anyone help me getting this communications connection set up between KINCO GL100 and KINCO K508-40AR? I am using Port 1(RS485) on the KINCO...
3,339
Hey, I have factorytalk studio ME version9.it will generate "unable to communicate with the factory talk linx server localhost" every time I try...
3,810
Hello everyone, I am stuck here with an OP77A HMI, the problem I am facing is that I am unable to open its loader as its startup delay(as I think)...
3,331
We have an HMI that when an application is loaded the HMI it asks if you want to change the terminal configuration settings to match the...
3,189
