Omron Cj1m
glenncovington
Apr 2002
Gloucester, VA
303
Hello all, I have a machine misbehaving this morning. Unfortunately, I do not have access to the PLC. The PLC is an Omron CJ1M CPU11. The OEM has sent me what I think is the original program, but I need to get it printed to PDF. Anybody out there that can open and print to PDF for me.
Thanks in advance.
Glenn
When I opened your program, there are quite a few sections showing error, it could be my version is not the latest. I am using CX Programmer Ver. 9.31. The following are some of the error, sorry
---------------- PLC: 'PLC' (PLC Model 'CJ1M CPU11' ) ----------------
Compiling...
[PLC/Program Name : PLC/Program]
[Ladder Section Name : Setup]
[Ladder Section Name : TouchPanel]
[Ladder Section Name : Recipe]
[Ladder Section Name : General]
WARNING: Rung exceeds the maximum size for online edit. (Extra: 75) - at rung 1 (0, 0)
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 2 ( 0, 13 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 2 ( 0, 10 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 2 ( 0, 7 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 2 ( 0, 6 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 2 ( 0, 5 ).
[Ladder Section Name : TopFeed]
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 1 ( 0, 6 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 1 ( 0, 5 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 4 ( 0, 38 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 4 ( 0, 34 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 4 ( 0, 27 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 4 ( 0, 25 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 4 ( 0, 21 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 4 ( 0, 17 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 4 ( 0, 8 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 4 ( 0, 6 ).
[Ladder Section Name : Bottom1]
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 1 ( 0, 4 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 6 ( 0, 2 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 7 ( 0, 58 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 7 ( 0, 54 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 7 ( 0, 45 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 7 ( 0, 42 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 7 ( 0, 38 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 7 ( 0, 29 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 7 ( 0, 26 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 7 ( 0, 22 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 7 ( 0, 13 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 7 ( 0, 11 ).
ERROR: Operand 2 Invalid IEEE Floating Point format at rung 7 ( 0, 6 ).
[Ladder Section Name : Bottom2]
part 1
Is this what you needed?
This is some of the sections. Had to post in 4 posts due to 5 files per post limit.
See attached files.
part 4
The rest of the files. Sorry for all the posts, maybe someone can combine the files and re-post.
Here is a screen shot of the file list so that you can view them in order.
See attached.
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
248
hi dear all hope you all are fine I have a problem with my CJ1M cpu11 ETN. it stop communication with PC over ethernet. ETN unit all indications...
169
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
159
i have been trying to connect to omron cj1m via peripheral port(USB to Serial), but there isn't any sign to show that it has connected, so am...
318
Has anyone encountered an error code 31 on an omron cj1m-cpu12? This error code is not covered in PLC manual.
521
