Step 7 Block title & network comment import?
jollylee
Nov 2008
Roscommon
Hi all
I'm currently working on a repeat machine project which uses siemens PLC control. I'm currently beginning to understand the original system for which I have two versions of program.
One is the original program which has all it's block titles, network titles and comments and symbols.
The second program is an up-to-date program which is the same apart from some minor parameter changes. It has no block titles, network titles and comments or symbols.
I'm almost sure I can migrate all the titles and symbols from the older version to the newer version but just can't figure it. If someone could help me with this they'd save me a days work. Thanks!
Joe
If you know the couple of parameters that changed you might be better off just making them in the copy of the project that has everything.
The symbols would be easy to drop into the other project, but I think the other stuff is harder to get back (the network titles, comments, ...) unless someone else knows an easy way.
BTW, the copy you have without the symbols and comments was most likely uploaded from the PLC. That's typically what is downloaded and so its all you get back. There are ways to store the entire project on the MMC but I've never used it.
Got it in one!
I've no idea without going through block by block which changes were made.
This used to work on MicroWin but haven't tried it for about 5 years. Back up the projects to new names just in case it makes things worse. Open the file with the comments in MicroWin, go through the program and make sure every line has a comment even if it only the word 'blank'. Now upload the correct program from the PLC, the PLC program bit should overwrite the existing program but leave the comments intact. If the corrected program has lines added then comments will be on the wrong lines, in this case add blank lines to the old program but give them network comments 'blank' before doing the upload.
Bryan
For the symbols: Open both projects, copy the symbols from the project with the documentation and paste it into the one without.
For the comments, you can export from the project with them and then then import them to the one with out. I think the import / export function is under the Options menu in Simatic Manager. Have the blocks selected first.
Thanks for the advice guys. I copied over the symbols file.
However when I export from the "manage multilingual texts" menu not all the information is exported. I've been attempting this on OB1 to get started. See here:
105-PG-001X - C:\Documents and Settings\modular\Desktop\Baxter fill rig\105PG001N\105_pg_1
Log file: C:\Documents and Settings\modular\Desktop\comment\export.txt
Date: 12/17/2009 Time of day: 09:40:55 AM
Settings: Source language: '9(1) English (United States)', Target language: '9(6) English (Ireland)'
Export from: OB1
Exported: BlockTitle
Exported: NetworkTitle
Exported: InterfaceComment
Export completed: 0 error(s), 0 warning(s)
Here is the log which is generated when I import into my uploaded program.
105-PG-001X_Upload060409 - C:\Documents and Settings\modular\Desktop\Baxter fill rig\upload\105-PG_1
Log file: C:\Documents and Settings\modular\Desktop\comment\import.txt
Date: 12/17/2009 Time of day: 09:41:11 AM
Read: C:\Documents and Settings\modular\Desktop\comment\InterfaceComment.csv
Read: C:\Documents and Settings\modular\Desktop\comment\NetworkTitle.csv
WARNING: Unable to find the file 'C:\Documents and Settings\modular\Desktop\comment\NetworkComment.csv'.
WARNING: Unable to find the file 'C:\Documents and Settings\modular\Desktop\comment\LineComment.csv'.
Read: C:\Documents and Settings\modular\Desktop\comment\BlockTitle.csv
WARNING: Unable to find the file 'C:\Documents and Settings\modular\Desktop\comment\BlockComment.csv'.
WARNING: Unable to find the file 'C:\Documents and Settings\modular\Desktop\comment\SymbolComment.csv'.
Project path: 105-PG-001X_Upload060409\SIMATIC 300(1)(1)\CPU 315-2 PN/DP\S7 Program(3)
Project path: 105-PG-001X_Upload060409\SIMATIC 300(1)(1)\CPU 315-2 PN/DP\S7 Program(3)\Blocks
Import for: OB1
Import for: OB82
Import for: OB100
Import for: OB121
Import for: OB122
Import for: FC10
Import for: FC14
Import for: FC15
Import for: FC16
Import for: FC17
Import for: FC18
Import for: FC19
Import for: FC21
Import for: FC22
Import for: FC23
Import for: FC30
Import for: FC100
Import for: FB2
Import for: FB3
Import for: VAT1
Import for: DB2
Import for: DB3
Import for: DB10
Import for: DB14
Import for: DB15
Import for: DB16
Import for: DB18
Import for: DB19
Import for: DB20
Import for: DB21
Import for: DB22
Import for: DB23
Import for: DB30
Import for: DB220
Import for: DB221
Import completed: 0 error(s), 4 warning(s)
None of the exported data is being imported to OB1. Anybody have this problem before?
When I open the uploaded OB1 I get the following error also.
There are no parameter & local variable names available because their description is not available or cannot be assigned.
Am I missing anything obvious?
Presuming its Step 7 here and not Microwin.
Make a copy before starting.
Have you compared the projects to see what the changes are.
If the differences are minor you could simply update the original code.
If there are too many, you could copy across all the blocks that are unchanged from the original to the undocumented back-up.
You can copy the symbols straight across, from the symbol folder from the original to the back-up.
From there on in it may take some time to get the undocumented blocks across, especially the DB's.
import
hello,
maybe my NetworkTitleEditor can help you. Please contact me. Or you compare both programs and make the changes in the program with comments
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
178
How can I do a search for a text string within a currently running PLC program? Our machine has keypads which display what the station is...
23
3,521
In TIA portal v13 where is in project file information about data block, function code block are stored ? Thanks
1,762
Just a quick question I can't find an answer on yet. I have created my own recipe structure using a Global DB and when I came in this morning...
2,018
Hello, I am trying to find an easy way to create data blocks in Step 7 with ~100K tags other than manually defining each tag in the LAD/STL/FDB...
14,206
