Sensor to Determine Volume
2rlp
Sep 2006
Mumbai
136
Have to determine volumes of packages on a conveyor. Client suggests that i utilise 3 ultrasonic analog sensors to do this. My concern is "what if the package has an odd shape?". Are there any sensors that can do this?
Ron
yes and no
ultrasonic will not be very precise and does not work well in a noisy environment.
so the best way is to use laser or infrared distance sensors.
if it gets complex you will need to use cameras.
Sorry friends, was busy with another project and didnt have time to thank you all for your replies.
Customer is adamant, and wants to use this 3 analog ultrasonic sensor system. wants a rough value of volume.
Thanks once again
There's a wide range of ultra sonic sensors and you can get better than mm precision. Package shape and its alignment on the conveyor is the problem here as you have 3 points only measured.
Hello, i am a beginner with a Siemens Logo 8 PLC. I would determine the direction of an object if it passes a whole cycle of 2 input sensors. See...
202
Hi. I'm new to allen bradley PLC's and PLC's in general. I've been asked to make a program that can determine the water flow of a machine. I...
1,690
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
90
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
120
Hi, Need help with coding for a faulty component sensor which we are using a push button as we are using a test rig. the plc is a allen bradley...
224
