Mitsubishi Q MELSECNET/H Transient Transfer Advice
MitsM83
Jan 2017
Indianapolis
90
Hello all,
I have 7 Q series PLCs on a Melsec net/h network, Ladder Programming none of that fancy smancy ST stuff LOL :p. Were running the QJ71LP21-25. Now to keep it short I have used all most all my devices in my Network Range Assignment. I can not set up low speed range as I do not have enough Link relays and registers at all stations. No memory for more devices just trust that I can not do it... However I have an abundance of File Registers ( no I cant buy B or W in the PLC File params, well I can but it wont help because only one CPU is UDE the rest are H.)
I have a project in which I must see about 50 words for each Station at every Station. I figured while I am setting up a Transient Transfer I will make a bunch of extra room for future updates and junk.
My answer good or bad, is to set up some Send/Recv commands and do some Transient Transfer. I think I have it just about all figured out just a few questions.
I have two manuals I have been getting my info from Q MELSECNET/H Network System Reference Manual ( I think SHNA080049) and the Melsecnet/h training manual.
1.Any one have any better manuals that better cover transient transfer? Or that are new enough to mention GX Works2 instead of Developer?
2. Is there a max device for each send/recv? (I keep thinking it is 980 per station but no idea where I got this number)( I will increase the max # of transients in the supplementary settings under network range...)
3. Any precautions or advice like, Hey don't do this, I did this once and....
4. It looks like as long as I use different logical channels for each station I should be able to send and receive multiple "messages" at once with no error?? (I will test this and look for the "no room in receive buffer area f222 error)
5. Will this slow down the Cyclic transfers (I will be watching the SW006D and so on to make sure it does not slow my regular transmission down.)
6. I will be using several special relays and registers in the program of course. Any I should use that are not obvious?
I have previously used a A1SJ71AP23Q card to bridge MelsecNet 2 to Q PLC. However, our local supplier told me that card is now obsolete. Has...
1,230
Hi, currently i have a Mitsubishi Melsecnet/Mini module installed in the A-Series PLC system. But this module no longer functional and I've bought...
2,155
We have three Mitsubishi A2N PLC connected through optical fiber cable. The Optical cable got damaged and we want to connect these PLC through...
1,681
So the customer purchased a Mitsubishi drive, in the same project for a different pump they got an ABB drive, was literally whatever they could...
48
hi all, I'm wondering if anyone has ever converted an Allen Bradley AOI to a Mitsubishi Function block. I's hard to find libraries from...
169
