Preeya
- Join Date
- Nov 2003
- Posts
- 112
I have some questions about Micrologix input filter. I feel that the filter settings I made (on the IO configuration) are not taking effect. I use a Micrologix 1200 series C, I have 2 high speed digitals inputs on inputs 2 and 3. I changed the input filter to the lowest - 25 microseconds.
When I go to help on the (embedded) IO configuration it says " The input filter time can only be adjusted by the time your program is developed" What does this mean?
Also, does anyone know what the default input filter delay is? When I go to the drop down menu for the filter it says - default, 25, 50, 100 microseconds etc It doesn't say what the default is..
Thanks for your time!
