TIA System Screens
boneless
Feb 2008
OKC
1,628
Hi all,
When one sets up a new hmi with the wizard, it is possible to add systems screens, is it possible to add these screens automatically in an existing project? Or alternatively, can the screens be updated when the screens are copied?
Hi all,
I don't know of a way to run the wizard retroactively. The screens could be copy/pasted in from another project, if needed. Really, all the functions on those screens can be added to any button; there's no magic in the wizard, just time savings.
What did you mean by "updated"?
Hi!
Yes we usually copy and update manually, it is not that much really. Project name, date, versions, connections etc. But since it is automated in the wizard, I was wondering why it is not possible to update it.
Hi!
If you're using a template, you might be able to change some things there, to save time. Also, hypothetically, you could make your own wizard with Openness, but you're starting from scratch in something like C++.
I'm hoping someone else knows how to restart the wizard, I've been wanting to do it as well, but never found a way.
I will let you know, it is a minor inconvenience, not enough to get me to write a script for it :)
I am working on a program that was developed in 2015 for an S7-300 safety PLC. The new copy of this machine uses an S7-1500 safety plc. We were...
1,930
Hi everyone I'm looking for some help with a problem please. I have a Siemens S7-1200 and 3 off KTP900 HMI's connected on the same Profinet...
2,003
Yo!!! I have a weird one. I am drawing a simple HMI for a machine to allow the maintenance team to calibrate a scale without needing to get the...
1,515
Greetings i have a high availability system containing of dual redundant system for the CPU , PS and communication CP(s) the configuration...
2,946
Hi all, Got a new project with a Siemens S7-300 (CPU 312). I've just tried to copy in my motor control FB's from an S7-1200 project I did earlier...
5,381
