Omron CX-One Online Issue
scottmurphy
Oct 2004
363
I am having a minor problem going online to my Omron PLC's via Ethernet.
The problem that I have, is that if I shut the lid of my laptop, then reopen again, I cannot get back online to the PLC without re-starting PC. My network settings are all ok, I can ping the PLC's, and can access other devices on network no problem, it appears CX-Prog does not want to connect.
As I said, not a major issue, but is easier to carry laptop to machine for mod's, troubleshooting etc with the lid closed.
I have not had any issues closing my lap top and getting on line with cx-one.
I suggest you check your power settings while on battery.
I set my lap top to DO NOTHING when I close the lid on batteries.
I also set the turn the monitor off at 2 hours and hard drive off at 4 hours. Hope this helps.
Hello, I am trying to use the pulse outputs to control an external servo or stepper drive that accepts pulse and direction inputs from the PLC...
1,991
Hi All, I have encountered a problem, Due to the large number of function blocks used I have run out of Retained and Non Retained space set aside...
1,056
I have a line that uses a Omron CS1G-H Processor. It runs every day. I loaded a copy of the program they had stored on disk into CX-Programmer...
3,942
Hello! I am trying to go online with an OMRON CS1G-CPU43H PLC. I can direct online through CX-programmer, and it reads the data out of the PLC...
2,771
I have a new CJ2M-CPU31 with one DO Card, one DI Card, and 1 Analog Card. I have the ethernet IP set to default 192.168.250.1 Node 0 I have not...
8,209
