Omron CP1H-X Pulse outputs not working with online simulator
chriswiseman
Feb 2010
Stouffville Ontario
25
Hello, I am trying to use the pulse outputs to control an external servo or stepper drive that accepts pulse and direction inputs from the PLC high speed outputs. I don't have the physical hardware yet so I am experimenting with the ladder logic programming using Omron CX-Programmer 9.61 with online simulator. The CPU is an Omron CP1H-X. I have changed the PLC settings for Output 0 to use normally open Limit Switches. Actually, I also tried NC limits as well. As you can see from the program attached, Axis 0 is not moving nor is the error bit set.
Perhaps the SPED function does not work with CX-Programmer online simulation? Has anyone had any success with this? If so, please let me know.
Hello all, I'm using a Omron CP1H-XA40DT-D programmed with CX-Programmer V9.3. I have programmed the Plc to move a camera on two axis on top of...
3,231
Hi all, I have to say first that I have no experience with Omron devices, but here's the challenge that I'm facing. I have an Omron CP1H...
1,709
I have a question about SET instruction in Cx-programmer. When condition goes true it is supposed to give value 1. But, my controller is giving 0...
24
2,289
Hello Sir/Ma'am, Hope you and your family are safe in this Covin-19 Pandemic. One of my client have a machine in their ceramic industry which...
2,618
Hi, I recently had to buy a batch of new electrical components containing 10 PLC Omron Type (CP1H-X40DRA) Apparently stored in store (to be used...
3,558
