Converting PNP output for device Expecting NPN output
ndzied1
Aug 2002
Chicago, Illinois
2,856
The subject question says it all.
I have a device with sinking NPN inputs and all my PLC outputs are set up to source current (PNP) with 24VDC on the common. :(
I have a device from OMRON to convert NPN to PNP (which i need for the other part of the interface) but it doesn't seem to work the other way around (OMRON PN EE-2002).
I can probably put a relay in to tie the device input to ground when the PLC output comes on but wondering about other methods?....
Help appreciated.
I recently posted a couple of bitmaps that should show you how to do it with a resistor for each connection. Remember that when you wire them this way, its like replacing a NO contact with a NC.
http://www.plctalk.net/qanda/showthread.php?s=&threadid=1615
The technique is fine for for one or two isolated connections, but it can be rather labor-intensive. If you have quite a few cross connections, it would be a lot easier to buy the correct flavor input module.
Thanks,
Yes, this is just one input and one output. The device I have handles the PLC Input side but not the output.
However, the whole issue is moot now as after I came back from lunck, the PNP flavor of the field device was sitting there on our receiving table. The rep originally said it would take 2 weeks to get (after our ship date) but he'd try to expedite it. I guess it worked 'cuz it's here now.
I'll keep your bitmaps handy for reference though... great info
Thanks again!
NOT banghead
They sent another NPN device!!!! ARGH!
But.... the resistor worked great .... once I figured out the function of my PLC output is now inverted.
Thanks ALL
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
208
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
122
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
317
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
389
Hello, This will be my first time converting powerflex 40's and 400's from devicenet to ethernet. I did some research, and it seems I will need...
751
