![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: Apr 2016
Controlling DC drive with Siemens PLC S7-1500
Hey Guy,
I would like to control the (attached) DC motor drive with my S7-1500 PLC through an HMI. when i say control i mean only the speed. any help is appreciated. Thank you, Sam |
#2 |
![]() ![]() Join Date: Feb 2012
This controller appears to be very basic and designed for control using a 10k potentiometer. You would need a motorized potentiometer like high end stereo equipment used once upon a time.
Personally I'd look at finding DC motor controllers that accept a 0-10V or 4-20mA reference signal |
#3 |
oh ! so not an easy one.
well, i will leave it as is. : ( |
#4 |
Supporting Member
![]() ![]() Join Date: Dec 2014
Depends what the control voltage is returning on S2, if its 0v to 10v then you can simply substitute this with a PLC analogue output.
Measure across S1 and S3 and see if it's 10v. |
#5 |
Janner10
thanks for the help. So i called the manufacturer and its 5V out and also they want me to use a Analog interface and isolation module. since i cant spend any money on this (project) i will have to let things be. thanks for all the help guys, Sam |
#6 |
![]() ![]() Join Date: Aug 2015
How many "Relay Outputs" can you dedicate to control the motor speed?
Build a Voltage Dividing Network, Example: put 5 resisters in series (lets say 2k each). That would only cost a couple of dollars! Now program the drive to have a min-max speed of let's 30hz - 70hz. Now wire each PLC relay output in between each resistor, now just program your hmi with a button for 70hz, then one for 60hz then one for 50hz then one for 40hz then one for 30hz, with each turning on the associated relay output. This would at least allow you to set various motor speeds, changing the resistor network would allow for different speed adjustments. Just an Idea - this would cost no more than a couple of dollars!!
__________________
David M. Camp Automation Engineer Marshall Electric / www.mei-tech.com PLEASE READ: https://www.prlog.org/12642091-marsh...-industry.html PLEASE READ: https://www.prlog.org/12680572-marij...hold-word.html |
#7 | |
Supporting Member
Quote:
Just restrict your 0v to 10v output from the PLC to a max of 5v. If your budget is zero, you haven't got many options. |
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
siemens s7 plc communication capability | panthripu | LIVE PLC Questions And Answers | 5 | February 5th, 2013 04:33 PM |
Citect SCADA with Siemens s7 300 PLC | Einstein_86 | LIVE PLC Questions And Answers | 5 | December 28th, 2011 09:28 PM |
Siemens S7 225 PLC Internet Module | ltrail | LIVE PLC Questions And Answers | 4 | January 25th, 2011 12:55 PM |
SCADA with S7 PLC by means siemens S7 PC/MPI cable | Andoni | LIVE PLC Questions And Answers | 4 | December 15th, 2008 07:04 PM |
VT510 as HMI for Siemens S7 PLC? | Angel Lopez | LIVE PLC Questions And Answers | 0 | October 1st, 2003 11:09 PM |
