Controlling SEW MDX61B drive with S7 400 PLC via Profibus using DFP21B Gateway
Dec 2019
Hansi
Hi All,
I am facing one issue with the SEW MDX61B drive.
Issue- I want to run a conveyor with this drive in two directions but it runs in only one direction.
System/Network Overview: I am using Siemens S7 416-2DP CPU with 2 SEW DFP21B gateway. on one gateway I have 6 MDX61B drives connected & on another I have 7 MDX61B drives, all communicating Via Sbus. All of them I can run in one direction CW but not in other CCW.
F.I. (Please Refer to attached image) If I want to Run BF05 then I turn on the Output Q579.1 & Q579.2. And then drive starts running. Could anyone please tell me what bits needs to be turned on in order to run the drive in another direction?
I have attached the image for more information. Please let me know if more information is required.
Any help would be much appreciated.
Thanks & Regards
Mohit
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe...
115
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
497
I'm a Manufacturing Engineer with limited PLC experience and I am doing some research for our Controls Department. Does anyone have experience...
183
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,067
More help again please... See the picture. I want to make the rectangle visible when Mr_Zr_ToggleSwitch is 1, and make it invisible when 0...
2,481
