Siemens S7/TIA v18: WinCC: Controlling the visibility of a rectangle.....
Mas01
Oct 2020
Leicester, England
1,109
More help again please...
See the picture.
I want to make the rectangle visible when Mr_Zr_ToggleSwitch is 1, and make it invisible when 0.
However, the "Single Bit" option is greyed-out.
Instead I'm forced to enter a range of values, but visible for range 1..1 and invisible for range 0..0 does not work because it applies either 0..0 or 1..1 to both the Visible and Invisible properties.
How can I enable the "Single Bit" option.
Mr_Zr_ToggleSwitch is defined as a Boolean.
I would not be surprised if like your other post that function keys have a visibility bit it also might disable it's function so if so you could swap the reset/set back on the bit for the storing of the data.
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi again, When the "REPORT" button is pressed (on a different screen), it takes the operator to the...
669
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi, The operator has reported that, from time-to-time, when he presses the "Generate Report" button...
466
General Question: The PLC and HMI that I've been working on (a laser measurement system) is soon to be transported to the site where it will be...
701
Hi, I'm not sure how to do this... Basically, I want to restrict the user input values for this tag to be in the range 20.001 to 25.0. I...
17
1,637
Can someone help me with this? I'm no good at SCL - virtually everything I've done so far has been ladder logic. The return value from the...
1,110
